2000 Chevy Malibu Anti Theft Device
Skunkpu
Member - Posts: 10
Posted: July 28, 2005 at 10:26 AM / IP Logged
Hey all.  New to this forum.  Need help.  Have a 2000 Malibu that the Anti Teft device comes on a lot of the time.  So I am stuck for 15-30 minutes at a time.  I hate this damn thing soo much.  Just need to know if the 2000 Mailbu has a passlock, passlock I, or passlock II system.  I believe I do not have a coded key.  The dealership wants to charge me $400 - $500 to replace the entire ignition switch and other parts associated with the ignition switch.  Not to mention they want to keep it for a week or more.  I just can't afford this type of money.  Any help would be greatly appreciated.  Thanks in advance.
iskidoo
Silver - Posts: 1,046
Posted: July 28, 2005 at 11:55 AM / IP Logged
2000 Chevrolet Malibu
Category: Immobilizer Bypass
Required: Yes
Type: Passlock II
Part#: 556LW
Notes:
Alternates: 555LW, 555T
http://directechs.com/directwire/wire_body.asp?action=select&yr=2972&product=Remote%20Start
Steve G
Skunkpu
Member - Posts: 10
Posted: July 28, 2005 at 2:50 PM / IP Logged
iskidoo,
Thanks for the help.  It is greatly appreciated.  Have a good day.
Skunkpu
Member - Posts: 10
Posted: July 28, 2005 at 2:54 PM / IP Logged
Don't suppose you know where it would be located on the 2000 Malibu?  Just a shot in the dark.  Thanks again.
iskidoo
Posted: July 28, 2005 at 5:20 PM / IP Logged
Should be in the Igntion Harness which is trickiy to get to.
To access the ignition harness remove the radio (without unplugging it) or the panel just above the radio.
Steve G
shesaidshewas18
Copper - Posts: 96
Posted: July 28, 2005 at 10:05 PM / IP Logged
Do you have an aftermarket alarm? If so, just hookup the factory dis-arm wire to your domelight output wire from your aftermarket alarm. I
Dsteinmann
Copper - Posts: 75
Posted: July 29, 2005 at 1:30 AM / IP Logged
you just need to replace the ingnition cylinder its about $175 from the dealer its pretty easy to install
shesaidshewas18
Copper - Posts: 96
Posted: July 29, 2005 at 3:37 AM / IP Logged
What is it exactly does he want to do though? If he just wants to shut it off, why spend $175 when you can just shut the factory alarm (Im assuming its the same as the anti-theft) could be dis-armed easily (Again, assuming he has an aftermarket alarm)
Skunkpu
Member - Posts: 10
Posted: July 29, 2005 at 7:50 AM / IP Logged
The car really isn't worth much resale.  Really don't want to dump more money into it than needed.  I just want to disbale the anti theft device.  Much cheaper than throwing another $175 plus eight hours of work on top of that 'cause I am not mechanically inclined.  Plus what happens if I screw something up.  Then I would probably be throwing much more money into it.  Cheaper to disable it.  That's it.  Thanks for all the input on this subject.
Hornshockey
Silver - Posts: 520
Posted: July 29, 2005 at 11:19 AM / IP Logged
I just read a thread on here not two days ago about disabling the Passlock anti-theft on GMs.  Guy got flamed pretty bad; but it might help you out.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
Friday, August 29, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
