wiring diagram for a 1996 dodge ram 3500
monte561
Posted: July 28, 2005 at 2:20 PM / IP Logged
Its a diesel.. and I want to hookp up a alarm/remote strater to it.. what avise can i get to hook this up on a 24v system?  And I need the wiring diagram.     Pls Help
thepencil
Gold - Posts: 1,526
Posted: July 28, 2005 at 2:40 PM / IP Logged
Hope the diagram will help you out. Are you sure it's 24V? wiring diagram for a 1996 dodge ram 3500 -- posted image. I've never seen one.
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 1996 / Remote Start
12volts red or pink/black    +   ignition harness
Starter yellow or blu/yel    +   ignition harness
Second Starter
Ignition dk. blue    +   ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ orange    +   ignition harness
Second Accessory
Keysense
Power Lock ORANGE / purple   5wi lt blue plug in driver kick
Power Unlock pink/purple   5wi lt blue plug in driver kick
Lock Motor
Unlock Motor
Parking Lights+ BLACK / YELLOW      yellow plug in driver kick
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow    -   yellow plug in driver kick
Dome Supervision use door trigger
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer gry/blk, blk/gry   AC   ignition coil
Notes: Also located as gray/blue at large plug through firewall on drivers side at highest point of firewall, also gray/blue at cluster.
Wait to start ORANGE / black   -   PCM
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall under the hood.
Brake Wire WHITE/ brown    +   brake pedal switch
Parking Brake
Horn Trigger dk. GREEN/ red    +   relay at fuse box
Notes: Also BLACK/ red (-) at column or relay.
Memory Seat 1
Memory Seat 2
Memory Seat 3
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Be careful whose advice you buy, but be patient with those who supply it.wiring diagram for a 1996 dodge ram 3500 -- posted image.
monte561
Posted: July 28, 2005 at 4:49 PM / IP Logged
thank you so much... and its a 12v excuse my mistake
thepencil
Gold - Posts: 1,526
Posted: July 29, 2005 at 11:50 AM / IP Logged
You are quite welcome.
