Toyota Factory Keyless Entry w/Ignition
toddc
Member - Posts: 15
Posted: December 01, 2002 at 1:39 PM / IP Logged
I just installed a remote start on my 2003 Toyota Matrix which uses the factory keyless entry to activate starting.  Unfortunately, the factory keyless entry will not operate while the car is running.  Does anyone know a way around this?  The car does not have an OEM alarm, so I'm hoping its just a matter of disconnecting the ignition sense wire to the keyless entry module.  Schematics and module location would be very helpful if anyone has them.  TIA
-Todd
finnman925
Member - Posts: 19
Posted: December 03, 2002 at 4:04 PM / IP Logged
I'll look it up for you tomorrow
Brian
mxxmikexx
Silver - Posts: 796
Posted: December 03, 2002 at 5:55 PM / IP Logged
why dont you just interface the remote starter to operate the locks and be done with it?
djfearny2
Silver - Posts: 810
Posted: December 03, 2002 at 6:18 PM / IP Logged
yea you can get a dei valet 551r and it has a remote and and keyless entry.
Jon
Installer/Help Technician
---coral springs florida---
toddc
Member - Posts: 15
Posted: December 03, 2002 at 6:57 PM / IP Logged
As I mentioned in my first post, I have a system that relies on use of the factory remotes to start the vehicle.  In retrospect, I should have purchased a unit that does everything.  I think I have found the location of the factory  keyless enty module.   Its located in the passenger side upper rear quarter panel, by the hatch.  My brother works at a Pontiac dealership and was able to pull the location drawing from the Vibe.  He also was able to get a wiring schematic, buts its pretty vague.  It only shows five wires coming out of the module.  Thoughts?
-Todd
diabloed
Copper - Posts: 133
Posted: December 03, 2002 at 10:50 PM / IP Logged
12volts
Toyota Factory Keyless Entry w/Ignition -- posted image.
 white & black
 ignition harness
Starter red  +  ignition harness
Second Starter N/A
Ignition BLACK/ white  +  ignition harness
Second Ignition BLACK / YELLOW  +  ignition harness
Third Ignition N/A
Accessory blue/red  +  ignition harness
Second Accessory N/A
Keysense blue/black  -  ignition harness
Power Lock green  -  passenger kick panel   Toyota Factory Keyless Entry w/Ignition -- posted image.
Power Unlock blue/black  -  passenger kick panel   Toyota Factory Keyless Entry w/Ignition -- posted image.
Lock Motor blue  5wi driver kick, door harness
Unlock Motor red  5wi driver kick, door harness
Parking Lights+ green  +  driver kick panel
Parking Lights- GREEN / WHITE  -  headlight switch
Hazards yellow/black  -  hazard switch
Turn Signal(L) GREEN/ red  -  steering column
Turn Signal(R) GREEN/ orange  -  steering column
Reverse Light RED / black  +  pin 11, conn. 3 @ PCM   Toyota Factory Keyless Entry w/Ignition -- posted image.
Door Trigger RED / yellow  -  driver kick panel
Dome Supervision comes on with unlock
Trunk/Hatch Pin common with door trigger
Hood Pin N/A
Trunk/Hatch Release blue/white  -  release switch on dash
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense
Tachometer black  ac  pin 5, conn. 4 @ PCM   Toyota Factory Keyless Entry w/Ignition -- posted image.
Wait to start N/A
Brake Wire GREEN / WHITE  +  brake pedal switch
Parking Brake RED / black  -  parking brake switch
Horn Trigger GREEN/ YELLOW  -  steering column
Sunday, November 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
