2001 Dodge Ram Car Alarm
CRjoslin15
Member - Posts: 12
Posted: August 15, 2005 at 12:12 PM / IP Logged
I just got my Excalibur ATV-1000 in the mail today.  I am looking to install it myself, I have done electrical work before, but not on an automobile.  At least, I think I am.  I am mainly looking for tips or hints as to things I need to look out for.  I will be adding door actuators in the near future, after I am sure the alarm went in okay.  My truck specs are below.  Is there anything that I need to look out for or be wary of in this model, alarm or truck?  Any tips that the wise ones can offer?
Thanks for any help you can give,
CRJoslin15
2001 Dodge Ram 1500 V6
No power door locks/windows
5-speed
Anything else I need to post?
CRjoslin15
Member - Posts: 12
Posted: August 15, 2005 at 1:16 PM / IP Logged
No remote start.  I thought that would be too risky with a manual tranny.
CRJoslin
CRjoslin15
Member - Posts: 12
Posted: August 18, 2005 at 10:08 PM / IP Logged
OK took a look under the dash and tried to compare wires before cutting and soldering.  I thought it was a good idea for a beginner, but I just ended up getting frustrated.  At any rate, I have a couple of questions.
1) My repair manual says to look for a dk blue / YELLOW wire coming from the ignition switch to tap into for the starter interrupt.  Well there is no db/yl wire there.  I look on the database here and it says to use the yellow wire.  I just want to make sure before I cut into it.  The yellow wire looks to be the same gauge as the wires on the relay.
2) Where should I tap into for the constant power.  I was thinking I could go through the firewall and use an opening in the main fuse box.  Or is there a better place under the dash?
3) Will it be incredibly hard to add pin switches and such later on?  I want to put a switch on the tail gate and the hood but really don't have the time right now.  Should I just go ahead and mess with it now?
I guess it won't be that hard because I only have to use one wire as the pin switch can just be a negative polarity switch.  Can I just change polarities like that?
Thanks for your help,
CRJoslin
mo12v
Posted: August 19, 2005 at 9:15 AM / IP Logged
Do all your connections under steering column area.....You have lots of room if you remove panel
MO
mo12v
Posted: August 19, 2005 at 9:16 AM / IP Logged
Constant 12 voltsRED & PINK/BLACKIGNITION SWITCH HARNESS
Ignition 12 voltsD BLUEIGNITION SWITCH HARNESS SEE TECH
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightYELLOW (-)26 PIN CONNECTOR BEHIND DRIVER DASH
Trunk Pin SwitchN/A
Parking LampBLACK / YELLOW (+)74 PIN CONNECTOR BEHIND DRIVER DASH
Power LockORANGE / VIOLET16 PIN CONNECTOR IN DR.
Power UnlockPINK/VIOLETKICK PANEL
Reversal Rest At Ground Door Locks
Accessories
Window UpD\ L BLUE P\ BROWN / WHITE @ MAIN SWITCH
Window DownR/ WHITE S/ VIOLET/WHITE
Ign Key WarnL BLUE (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornBLACK/ RED (-)74 PIN CONNECTOR BEHIND DRIVER DASH
HeadlightsL GREEN (-)AT HEADLIGHT SWITCH
OEM Alarm ArmN/A
OEM Alarm DisarmL GREEN/ ORANGE (-)IN PIN 8 OF A 16 PIN CONN DR.KICK *
Reversal Rest At Ground Power Window Circuit
* OEM DISARM* Connector Located In Body Harness Side Of Drivers Door Harness To Disarm Ground Thru A 1565 Ohm Resistor
Remote Start
Tach SignalBLACK/ GRAYAT POWERTRAIN CONTROL MODULE *
Ignition #2BLACK/ ORANGEIGNITION SWITCH HARNESS SEE TECH
Ignition #3N/A
AccessoryBLACK/ WHITEIGNITION SWITCH HARNESS
Neutral SafetyBLACK/ WHITE (-)AT SWITCH ON TRANSMISSION OR PCM *
Brake LightWHITE/ TAN (+)AT SWITCH ABOVE BRAKE PEDEL
Reverse LightVIOLET/BLACK (+)AT SWITCH ON TRANSMISSION
Rear Window DefrostN/A
* Power Train Control Module (PCM) Is Located On Passenger Rear Of Engine On Firewall. BLACK/ GRAY On 8.0L Engine Is 2 Cylinder Signal.(From Installer Tach Wire GRAY/BLACK) Diesel Glow Plug Wire Is ORANGE / BLACK At PCM. Can Also Be Found At 74 Pin Connector Behind Instrument Cluster.
MO
mo12v
Posted: August 19, 2005 at 9:18 AM / IP Logged
Also..........OMEGA TECH LINE......888-921-8324 if you really need help
MO
CRjoslin15
Member - Posts: 12
Posted: August 20, 2005 at 8:24 AM / IP Logged
Well, I hooked everything up and ... nothing.  The alarm goes off when I turn the ignition to the "on" position.  Well, I finally, somehow, got the transponders programmed.  Once I found out that I had to strip the pk/bk wire not the bk/pk I got somewhere.  Only to find that the pk/bk wire was not a constant 12V either.  Does anyone know of another wire that I can use for a constant 12V?
Thanks,
CRJoslin
mo12v
Posted: August 20, 2005 at 8:35 AM / IP Logged
If you are using the wires at the Ignition Switch harness:
RED is Constant................
MO
CRjoslin15
Member - Posts: 12
Posted: August 20, 2005 at 9:06 AM / IP Logged
Thanks, I just found that out.  Got it working!  Thanks for your help and diagram!  No the only problem that remains is that I cannot program it.  The valet switch used to program it is not getting any response.  There is no confirmation chirp when I press it five times.
One other minor issue is the dome light.  I think though that the wires are not making good contact.  But that is of little concern at the moment.
Any ideas on the valet switch?
Thanks,
CRJoslin
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
