Posted: August 17, 2005 at 10:26 PM / IP Logged
Posted: August 18, 2005 at 12:03 AM / IP Logged
Posted: August 18, 2005 at 12:09 AM / IP Logged
Posted: August 18, 2005 at 12:40 AM / IP Logged
Posted: August 18, 2005 at 2:11 AM / IP Logged
Posted: August 18, 2005 at 2:20 AM / IP Logged
Posted: August 18, 2005 at 2:33 AM / IP Logged
Posted: August 18, 2005 at 2:37 AM / IP Logged
Posted: August 18, 2005 at 2:39 AM / IP Logged
Posted: August 18, 2005 at 10:02 PM / IP Logged
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
that is the wiring diagram i recieved with my alarm... my questions are.
the backwards ignition coil from 87a(lol) - where does that go?
IGNITION 1 PINK ?
were does the thick yellow from 87 go?
12 VOLTS CONSTANT RED?
where does ACC (i/p +) from 86 go?
STARTER YELLOW?
where is the ignition harness?
that relay that they gave me with the alarm system, where should i put it?
i tapped the orange wire for the brake... i guess i have to change it to the white
i have already diode isolated the doors, and i am 99% sure i did that correct.
now for the two white wires for the hazard lights this is what i did. i tapped a light blue wire and a dark blue one from the harness at the steering column that goes to the turn signal lever. i connected one white wire to the lt. blue, and i connected the other white wire to the dk. blue. did i do that wrong?
please help, i have been trying to do this for days and the people at the jbody.org forum who only have these cars were the most ignorant people i ever encountered on a forum. thanks.
