1998 Grand Cherokee Remote Start w/ Factory Remote
jeepcj92
Member - Posts: 46
Posted: December 05, 2002 at 6:33 PM / IP Logged
I have a 1998 Jeep Grand Cherokee Limited.  It has the memory seats, mirriors etc and I would like to install a remote start.  However I do not want to give up the factory buttons because of the memory seating and I don't really want to lug around two key fobs for one car.  So I have an idea that I am wondering what everyone thinks:  The unit I have is a Prestige Platnium APS 685.  It has an auxilarry  input that will start the vehicle when pulsed ground.  Could I: 1 use the panic button channel from the factory remote hooked via a relay to pulse the remote start to ground and thus start the vehicle? and disable the panic... just using that channel to start the Jeep?
2. Or Does anyone know if there is a smaller single button remote that will work with the prestige remote start?
any thoughts?
thanks
-Jeff
darren611
Member - Posts: 8
Posted: December 05, 2002 at 7:24 PM / IP Logged
I hope someone has the answer for you, i was trying to do the same thing with my 97 mustang. for now i'm using 2 remotes
the12volt
Administrator - Posts: 3,959
Posted: December 05, 2002 at 7:34 PM / IP Logged
You can add a channel expander to your factory keyless entry to do just what you described.
the12volt
Posted: December 05, 2002 at 7:37 PM / IP Logged
Here's one that I've used to do what you want to do.
lalur
Member - Posts: 27
Posted: December 05, 2002 at 7:49 PM / IP Logged
hey bro audiovox makes an alarm that works with the factory remote it works of the motor wires so to start the vehicale u would push lock unlock lock and the car would start
any help ask
jeepcj92
Member - Posts: 46
Posted: December 06, 2002 at 9:53 PM / IP Logged
Anyone know of a good source for this?
Nate_Dogg
Member - Posts: 35
Posted: December 07, 2002 at 11:10 AM / IP Logged
There are a lot of starters on the market that utilize the lock -lock feature to start your car with factory remotes.Try Omegas rs-4lx or code alarms f-40.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
