trunk release
djambush
Member - Posts: 39
Posted: December 06, 2002 at 8:32 AM / IP Logged
I am trying to figure out how to connect the AUX channel for the trunk release.
94 Accord EX, do I need a RELAY?? The manual does not say use a relay it just says AUX channel for window mod or trunk release. Im so lost.
The unit is a Crime stopper 2011 RS.
Any ideas?
--Ambush
Platinum - Posts: 12,488
Posted: December 06, 2002 at 9:33 AM / IP Logged
Yes, you need a relay. Does the Accord have a power trunk release button ? If so , then you will need to reverse the polarity on the AUX channel ( if it's a - trigger ) and attach it to the trunk release. Use the NEGATIVE------>POSITIVE OUTPUT diagram here: http://www.velocitymotorsport.com/install_notes/Converting_Outputs.jpg
djambush
Member - Posts: 39
Posted: December 06, 2002 at 12:29 PM / IP Logged
Yeah...
It is power. the LEVER popup type like the ones on the hatch-back acuras/hondas.
I guess ill try that then. Thanks.
--Ambush
Posted: December 06, 2002 at 12:38 PM / IP Logged
If it's a lever pull type, then it's not power rather a manual pulling of the cable that opens the release meachanism. You will need to install a power trunk release solenoid on the cable at the lock mechanism on the trunk lid for this to work with the remote sontrol of the RS unit/alarm system. I know some Honda's have the OEM power trunk release button that is POWERED and you press the button and it pops the trunk, NO PULLING of a lever, just the button.
joelr7309
Copper - Posts: 97
Posted: December 09, 2002 at 12:51 PM / IP Logged
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
