remote starter/alarm, 2006 GMC Denali XL
dmurray14
Member - Posts: 48
Posted: October 01, 2005 at 2:02 PM / IP Logged
Hey guys,
About a year ago I installed an Autopage RS720lcd in my 2001 Chevy Suburban. Now that vehicle is getting traded in for a 2006 GMC Denali XL, and I'd like to move the remote starter/alarm over to the new vehicle. Does anyone have any experience installing on a 05/06 Denali? What differences will I see? Does it still use the Passlock II system, or something new? Also, would anyone have the wiring colors and locations for the starter and alarm portion of the install for a Denali? Any words of wisdom?
Thanks guys,
Dan
dmurray14
Member - Posts: 48
Posted: October 01, 2005 at 9:01 PM / IP Logged
Anyone? Need to get this taken care of on Monday, would really appreciate any help!
Thanks!
Dan
cntrylvr79
Silver - Posts: 582
Posted: October 02, 2005 at 12:20 AM / IP Logged
All the parts from you're old alarm will transfer over.  Your also going to need a databus interface for the doorlocks.  would be a 456g.  Never dealt with the system you're talking about so I can't be much help there, but if you got it into the silverado the yukon is for the most part the same.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Platinum - Posts: 12,488
Posted: October 02, 2005 at 11:11 AM / IP Logged
Dan, I would go and get a new bypass module for the Passlock system. For one reason, the new Passlock II bypasses will also have other features that can be used by the user like Lock/Unlock, Driver's Priority Unlock, Trunk/Hatch, OEM Security Arm/Disarm, Door trigger Output (-) & Override the 2nd /3rd generation GM Passkey3 Transponder Immobilizer & Passlock 2 Immobilizer via data bus. Some of the newest versions also have tach wire output, the defroster, the parking light output, heated seats & mirrors as well as RAP shutdown. This makes the installion way easier and worth the extra couple of bucks in the end.
dmurray14
Member - Posts: 48
Posted: October 02, 2005 at 5:26 PM / IP Logged
Jeff,
Thanks a lot for the reply. Do you know which bypass module has all the features you listed, including the parking light, heated seats, etc? Would really appreciate it.
Thanks!
Dan
dmurray14
Member - Posts: 48
Posted: October 02, 2005 at 5:59 PM / IP Logged
OK, I found the Crimestopper GM SL which seems to be what you're talking about, but I can't for the life of me figure out where to buy it. Any help is apprecaited...need to do this quickly. Thanks!
Dan
mo12v
Posted: October 03, 2005 at 8:23 AM / IP Logged
Where are you located?
MO
Satkunas
Copper - Posts: 97
Posted: October 03, 2005 at 9:27 AM / IP Logged
dmurray14 wrote:
Jeff,
Thanks!
Dan
The CAN SL ( Can Bus Bypass )
dmurray14
Member - Posts: 48
Posted: October 03, 2005 at 11:03 AM / IP Logged
Thanks guys, but I still can't figure out where to order. The CAN SL looks perfect, but it's not out yet? Need to order today. I'm in NJ...
Thanks,
Dan
dmurray14
Member - Posts: 48
Posted: October 03, 2005 at 12:15 PM / IP Logged
Satkunas wrote:
dmurray14 wrote:
Jeff,
Thanks!
Dan
Can you confirm that my 06 Denali has the CAN bus? Also, is there any place I can order it now, or do I have to wait until the 17th?
Thanks,
Dan
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
