Remote Start
Hickmanae3
Copper - Posts: 67
Posted: October 17, 2005 at 12:43 PM / IP Logged
Car  -  97 ford explorer ( eddie bauer)
Alarm - Syctek galaxy 8000
When i try to remote start my car, it does not crank up. The radio and stuff comes on but not the ignition. I tried turning on the car first and after letting the car  run for 3 minutes. I took the key out and then tried the remote starter again, At that time the ignition crank on properly. The third experiment i tried is after waiting 6 hours. I tried to remote start my car again. And soon enough i had the smae results from the first experiment which was only the radio and power come on.  so I stuck the key in the ignition and tried the remote start and the car remote started properly. So is there any theory to sum all three experiments up as to what is going on.
No security system can beat the tow truck :(
Joe Neal
Copper - Posts: 113
Posted: October 17, 2005 at 12:59 PM / IP Logged
Did you hook up Dis Arm??
OEM Alarm DisarmD GREEN/ PURPLE (-)DRIVER KICK PANEL
Hickmanae3
Copper - Posts: 67
Posted: October 17, 2005 at 11:00 PM / IP Logged
nope,
auex
Platinum - Posts: 5,041
Posted: October 18, 2005 at 12:15 AM / IP Logged
Did you install a bypass for the factory immobilizer?
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
tragik
Copper - Posts: 169
Posted: October 18, 2005 at 1:09 AM / IP Logged
sounds like your car needs a transponder bypass. When the remote start fails, look for a flasking light on the dash that says THEFT. If you see it, then you need to bypass the P.A.T.S. (passive anti-Theft System).
Northstart.....or start it your damn self.
