2000 Chevy Venture Remote Starter
campuschill
Member - Posts: 13
Posted: October 25, 2005 at 4:49 PM / IP Logged
I am trying to install a Code-Alarm CSI 400 remote starter system in a 2000 Chevy Venture, with a DEI 555G Passkey III bypass. I would like to know if i need the SPDT relays for this installation. I will appreciate any help. Thanks
mo12v
Posted: October 25, 2005 at 5:34 PM / IP Logged
That depends on what you need them for..????
Constant 12 voltsRED & RED / WHITEIGNITION SWITCH HARNESS *
Ignition 12 voltsPINKIGNITION SWITCH HARNESS
StarterYELLOWIGNITION SWITCH HARNESS
Dome LightGRAY/BLACK (-)AT BULK HEAD CONN.UNDER DRIVERS DASH
Trunk Pin SwitchGRAY/BLACK (-)SAME AS DOME LIGHT WIRE ABOVE
Parking LampBROWN (+)AT HEADLIGHT SWITCH ***
Power LockL BLUE10 PIN CONNECTOR IN
Power UnlockWHITEDRIVER KICK PANEL
* Separate Circuits - RED Fused At 60 And RED / WHITE Fused At 40 Amps. ** Alternate Door Trigger Circuit: TAN (Dr), D BLUE (Ps Front And Liftgate) And ORANGE (Sliding Door) (-) At Body Control Module Below Passenger Dash. Diode Isolation Needed, Cathode (Band) Side Of Diode Faces OEM Wires. *** BROWN (+) Wire Also Located In 56 Pin Conn. Near Driver Kick Panel.
Negative Pulse Door Locks
Accessories
Window UpD\ D BLUE P\ L BLUE @ MAIN SWITCH
Window DownR/ BROWN S/ TAN
Ign Key WarnL GREEN (-)48 PIN CONN. AT BASE OF STEERING COL.
Trunk ReleaseN/A
OEM HornBLACK (-)STEERING COLUMN HARNESS
HeadlightsYELLOW (+)AT HEADLIGHT SWITCH *
OEM Alarm ArmRED / BLACK (-)
OEM Alarm DisarmORANGE / BLACK (-)IN DRIVERS KICK PANEL
Reversal Rest At Ground Power Window Circuit Diagram.
* YELLOW (+) Wire Also Located In 48 Pin Black Connector At Base Of Steering Column. ** OEM Alarm Arms By Locking Doors Thru OEM Keyless Entry Transmitter Or By Locking Doors Using Inside Door Lock Switch While Driver Door Is Open.
Remote Start
Tach SignalWHITEAT POWERTRAIN CONTROL MODULE *
Ignition #2ORANGEIGNITION SWITCH HARNESS (HEAT/AC)
Ignition #3WHITEIGN. SW. HARN. (INSTRUMENT CLUSTER)
AccessoryBROWNIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightWHITE (+)AT SWITCH ABOVE BRAKE PEDAL
Reverse LightL GREEN (+)56 PIN CONN. TO LEFT OF STEER. COL.
Rear Window DefrostN/ATIMER BUILT INTO SWITCH
* Powertrain Control Module Located On Driver Front Of Engine In Air Cleaner Housing.
Immobilizer Bypass
MO
campuschill
Member - Posts: 13
Posted: October 25, 2005 at 5:49 PM / IP Logged
MO,
Thanks for your response. I did not understand your question. I would like to start the van with the RS system and have it warm and also the rear defogger ON. I have OEM keyless entry in the VAN. Please advice.
gus1
Gold - Posts: 1,013
No you will not, however, the 555G will "hang" the security light when you take over with the key. It's nothing that you did, it is a software issue in the 555G.
Gus
PS- PKG-5 works a lot better!
campuschill
Member - Posts: 13
Posted: October 25, 2005 at 6:00 PM / IP Logged
Thanks Gus.
Which is the security light? What is PS-PKG-5?
Also in-case i want to use the keyless entry system from the CSI-400 instead of the OEM, would i need the relays or any additional components.
gus1
Gold - Posts: 1,013
Posted: October 25, 2005 at 6:07 PM / IP Logged
The security light is the one that says "security" in the dash....
And, no, you do not any relays (already answered that)
PS- Post script.
It is just PKG-5 from either Automobility or Bypasskits.....
Gus
mo12v
Posted: October 25, 2005 at 6:16 PM / IP Logged
Also
OMEGA
GM Passkey 3 & Passlock 2 Override Interface (DB-PASS-23A)
    2000 Chevy Venture Remote Starter -- posted image.
2000 Chevy Venture Remote Starter -- posted image.2000 Chevy Venture Remote Starter -- posted image.GM Passkey Transponder Bypass: Grand Prix 2004 (IB-UGM)
MO
campuschill
Member - Posts: 13
Posted: November 02, 2005 at 5:12 PM / IP Logged
I am going to install the RS tomorrow. Meanwhile a friend tells me that it would be better if i disable the airbag system before i start this work. He feels that i might trigger the airbag deployment by mistake. Is there a possibility for this to happen, if yes, is there a way to disable the airbag system temporarily untill i install the RS and how?
tjdurham
Copper - Posts: 180
Posted: November 02, 2005 at 10:12 PM / IP Logged
DO NOT DISABLE THE AIRBAG""""""" Just stay away from any wires covered in a yellow tubing and use a digital meter to test your wires if your are not sure
tj
Chris Luongo
Platinum - Posts: 3,746
Posted: November 03, 2005 at 6:09 PM / IP Logged
Don't worry about the airbag; just avoid yellow-taped wires as others have said. When you try operating the various functions of the remote for the first time, it would always be wise to be away from the airbag when doing so, just in case.
Does your Venture have a factory alarm? There are two different ways you should do the locks, depending on whether you have an alarm or not.
Open a window. Lock the doors with the factory remote. Leave the car alone for at least 30 seconds. Reach in through the open window and "break into" the car. Do you hear the horn sounding?
Page of 3
Monday, December 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
