ABS Light & Remote Start?
itsmike
Member - Posts: 6
Posted: October 26, 2005 at 12:44 PM / IP Logged
On my 00 Honda Accord with Viper 550ESP (RS) Recently, whenever I remote start I get the ABS light and it doesn't go out.  If I key start everything works normally (the light comes on and then goes out).
Anyone have any ideas as to what recently went wrong with the alarm??
extreme1
Silver - Posts: 1,070
Posted: October 26, 2005 at 12:48 PM / IP Logged
you have an accesory wire being powered during crank.
test all your wires with the key and find out which one's stay on during crank and which ones drop during crank and set starter up accordingly
Shaughn Murley
Visions Electronics
Red Deer, Alberta
itsmike
Member - Posts: 6
Posted: October 27, 2005 at 7:59 PM / IP Logged
Which wires would cause the ABS light to stay on?
Chris Luongo
Platinum - Posts: 3,746
Posted: October 27, 2005 at 11:41 PM / IP Logged
Like extreme1 said, just test each wire while operating the remote start, and see which one is not working properly.
The accessory wire that comes on while the key is in the radio position---you don't even need to power that one up at all if you don't want to.
