02 dodge ram keyless entry?
eeh1025
Copper - Posts: 113
Posted: November 08, 2005 at 9:03 AM / IP Logged
hey guys im hooking up a crimestoppers cs-2004dc, my question is which is the door locks in the 02 dodge ram
positive trigger
negative trigger
reverse polarity
pss5075104
Copper - Posts: 144
Posted: November 08, 2005 at 9:09 AM / IP Logged
Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
mo12v
Posted: November 08, 2005 at 9:10 AM / IP Logged
Power LockWHITE/ DARK GREEN14 PIN CONNECTOR IN DRIVER
Power UnlockSINGLE WIRE SYSTEMKICK PANEL ***
*** WHITE/ DARK GRN Wire Must See Ground Through 820 Ohm Resistor For Lock And Ground Through 330 Ohm Resistor For Unlock.Alt: 220 Ohms. Confermed By More Than One Source The 220 Ohm Worked On Unlock.  Single Wire Resistor Door Locks
MO
eeh1025
Copper - Posts: 113
Posted: November 09, 2005 at 3:45 PM / IP Logged
if the alarms says onboard relay for the locks do i still need one
mo12v
Posted: November 09, 2005 at 4:27 PM / IP Logged
NO..........Hook it up for NEGATIVE Pulse..........But you will either need the correct Resistors or a Resistor Interface like the
OMEGA DLR-U
or OMEGA
Chrysler Doorlock interface & Immobilizer Interface/Bypass (DB-CHDL3P)
    02 dodge ram keyless entry? -- posted image.
MO
eeh1025
Copper - Posts: 113
Posted: November 09, 2005 at 4:31 PM / IP Logged
okay one more thing my radio shack has the 1/2watt 330 resistor but only has up to a 680, is there a alternative like i read you could use a 330ohm or 1.4k ohm is there one for the 820?
thanks
