2000 Toyota Rav4, Hornet 563T
menavex
Posted: November 14, 2005 at 7:34 AM / IP Logged
Ok so I decided to install a hornet 563T into my 2000 Toyota Rav4. So far I've got the key-less entry and alarm part working.
I have a question about the the satellite relay part of the install. The wires are thick, (like maybe 12 gauge wire?) but at the ignition switch the wires a tiny 18 gauge wire. Is this really where I should make there connections?   Here is the install manual .
I was thinking I could cut the ribbon and just connect it like that. The relay does not seem to be needed.
2000 Toyota Rav4, Hornet 563T -- posted image.
Also does anyone know if I have a built in neutral safety switch in the rav? I guess I could just field test it. If I don't hunting down the wire in the rav won't be that hard.
menavex
Posted: November 14, 2005 at 5:42 PM / IP Logged
Hmmm, maybe I poorly formed my question. I am quite the novie, let me re-phrase it.
I see the starter, ignition and acc wire under the steering column. These wires come out of the they key ignition part and go on to some unseen relay.
I am installing a remote start kit with a relay satellite. The satellite has these big gauge wires that is meant to switch high current.
Should I connect the satellite relay to these small 18 gauge wires?
If not, I guess I should follow these wires to the relay they control. And do my connections there.
mo12v
Posted: November 14, 2005 at 6:10 PM / IP Logged
CORRECT...............The R / S's are made for a varity of Vehicles, so they have to have the Guage wire you refered to.
Hook up, as your Instructions show & ( if you have ) Vehicle Wiring Guide......
SEE NOTE Below: for Constant 12 Volts
Constant 12 voltsWHITE & BLACK/ RED *IGNITION SWITCH HARNESS
Ignition 12 voltsBLACK/ WHITEIGNITION SWITCH HARNESS
StarterRED (AT), BLACK/ WHITE(MT) IGNITION SWITCH HARNESS
Dome LightRED / YELLOW (-)7 PIN ORANGE CONN. AT FUSE BLOCK **
Trunk Pin SwitchRED / WHITE (-)7 PIN ORANGE CONN. AT FUSE BLOCK **
Parking LampGREEN (+)11 PIN CONN. AT FUSE BLOCK
Power LockBLUE/WHITE16 PIN BLUE CONNECTOR
Power UnlockBLUE / YELLOWIN DRIVER KICK PANEL
Child Safety Door Locks.
Wire Color Is BLUE/ORANGE * WHITE At Ignition Switch Fused At 10 Amps, BLACK/ RED At Ignition Switch Fused At 5 Amps. For Alarms And Remote Starters Use WHITE Wire At Fuse Box.
** RED / YELLOW (-) Wire Covers The Two Front Doors Only, RED / WHITE (-) Wire Covers All Rear Doors. Diode Isolation Needed.
Window UpD\ GREEN P\ GRN/RED D\ BLU/BLK P\ RED / YEL @ MAIN SWITCH
Window DownF/ YELLOW F/ BLU/WHT R/ BLU/RED R/ RED / BLU
Ign Key WarnBLUE/BLACK (-)IGNITION SWITCH HARNESS
Trunk ReleaseN/A
OEM HornGREEN/ RED (-)STEERING COLUMN HARNESS *
HeadlightsRED / WHITE (-)AT HEADLIGHT SWITCH
OEM Alarm ArmN/ANO OEM ALARM
OEM Alarm DisarmN/APRESENT IN SCHEMATICS
* Horn Wire Also Found In 23 pin Connector At Intergration Relay Behind Driver Dash - Above Relay Block
Reversal Rest At Ground Power Window Circuit
Tach SignalBLACKAT ENGINE CONTROL MODULE *
Ignition #2BLACK / YELLOWIGNITION SWITCH HARNESS
Ignition #3N/A
AccessoryBLUE/REDIGNITION SWITCH HARNESS
Neutral SafetyNOT GROUNDING TYPE -OEM SWITCH OPENS STARTER CIRCUIT
Brake LightGREEN / WHITE (+)AT SWITCH ABOVE BRAKE PEDAL **
Reverse LightRED / BLACK (+)4 PIN CONNECTOR IN DRIVER KICK PANEL
Rear Window DefrostBLACK/ BLUE (+)AT REAR WINDOW DEFOGGER SWITCH
* Engine Control Module Is Located Below The Center Console.
** Brake Wire Also Found At 11 pin Connector in Driver Kick Panel
NOTE : WHITE At Ignition Switch Fused At 10 Amps, BLACK/ RED At Ignition Switch Fused At 5 Amps. For Alarms And Remote Starters Use WHITE Wire At Fuse Box. Remote Start Will Blow These Fuses.
MO
