2000 Pontiac Bonneville
ksutton
Copper - Posts: 94
Posted: November 14, 2005 at 6:42 PM / IP Logged
im doing one of these cars and just would like to know is there anything hard or need to know about this car
mo12v
Posted: November 14, 2005 at 9:08 PM / IP Logged
Pretty straight forward........Depending on your Application:
You may need to go to the Battery for Power:
Constant 12 voltsORANGEIGNITION SWITCH HARNESS
* ORANGE Wire Is Fused At 15 Amps Only
MO
northern
Copper - Posts: 154
Posted: November 14, 2005 at 11:06 PM / IP Logged
Mo12v, as a follow up question, what gauge wire would you need to take from the battery to the drivers kick panel?
Chris Luongo
Platinum - Posts: 3,746
Posted: November 15, 2005 at 7:54 AM / IP Logged
All the ignition wires in that car are low-current. I use the power source at the ignition switch with no troubles-----use NEGATIVE TRIGGER parking lights, and for the remote starter, install a fuse that is less than 15 amps---a 10, 7.5, or even 5 is fine.
If you don't like the idea of getting power at the keyswitch, there is a thick orange wire in the kick panel under the carpet.
Don't forget that your car has PASSKey III; there's a transponder in the key. You can give up one of your spares and plant it in a bypass box, or it's easy to buy an uncut key from howardkeys.com, hlflake.com, ebay.com, or a local locksmith, and program it yourself.
mo12v
Posted: November 15, 2005 at 8:10 AM / IP Logged
Depending on the application, I usually use 12 Guage with 20 Amp Fuse at the Battery.
Also, ....probably for the price of a key and a little less hassle you could get one of these Modules from OMEGA:
GM Passkey 3 & Passlock 2 Override Interface (DB-PASS-23A)
    2000 Pontiac Bonneville -- posted image.
2000 Pontiac Bonneville -- posted image.2000 Pontiac Bonneville -- posted image.GM Doorlock Alarm & Transponder/Passlock Interface (DB-GMDLBP)
2000 Pontiac Bonneville -- posted image.2000 Pontiac Bonneville -- posted image.Multi Vehicle Databus Doorlock Alarm Interface (DB-DLMT)
2000 Pontiac Bonneville -- posted image.2000 Pontiac Bonneville -- posted image.GM Passkey Transponder Bypass: Grand Prix 2004 (IB-UGM)
MO
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
