2002 chevy van
jimmythegreat1
Member - Posts: 35
Posted: December 13, 2002 at 9:36 AM / IP Logged
Hey guys, and gals if any. I am doing a prestige 785 in an astro van full size, custom I will be doing the remote start also the van already has keyless entry can I tap into these somehow? let me know will ya. also another diagram would be nice I also will be using the 55L for the pass lock, question how do I know that the vehicle has the pass lock the key looks normal with no chip in it.
jimmythegreat1
Member - Posts: 35
Posted: December 13, 2002 at 9:58 AM / IP Logged
The lady wants the drivers door to unlock when i hit unlock but the other doors to open with like a 2cond option button also the rear door to unlock seperate also.
10nesne1
Silver - Posts: 284
Posted: December 13, 2002 at 10:45 AM / IP Logged
Chevrolet
Astro Van
1996-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
YELLOW
IGNITION SWITCH HARNESS **
Ignition  #1:
PINK
Ignition #2:
WHITE
Ignition  #3:
N/A
Accessory:
ORANGE
Brake  Light:
WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
WHITE
AT IGNITION COIL *
Parking Lights:
BROWN (+)
AT HEADLIGHT SWITCH
Headlights:
YELLOW (+)
AT HEADLIGHT SWITCH
OEM Alarm  Disarm:
N/A
IN SCHEMATICS
OEM Alarm  Arm:
N/A
NO OEM ALARM PRESENT
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * Ignition Coil Located On Top Of Engine Behind Generator.** 1998+ Vehicles Are Equipped With GM's PASSLOCK II Anti-Theft System; See Note #113 - Bypassing GM's PASSLOCK II Passive Theft System Diagram.
Chevrolet
Astro Van
1996-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
RED (2)
Starter  Kill:
YELLOW
Ignition  +12 Volts:
PINK
Dome  Lights/Superv:
PURPLE (-)
AT ANY PIN SWITCH ****
OEM Horn:
BLACK (-)
STEERING COLUMN HARNESS
Power  Lock:
L BLUE
DRIVER'S KICK PANEL*****
Power  Unlock:
WHITE
Trunk  Release:
L GREEN (-)
AT REAR WINDOW RELEASE SWITCH
Alarm  Input Wire:
PURPLE (-)
Notes:
**** WHITE (-) At Courtesy Light Can Also Be Used For Door Trigger.***** See Note #202 - Positive Pulse Door Lock Diagram.
The driver's door unlock first, you will have to cut the driver door motor unlock wire and hook up a relay to it. Then the connect the door lock and unlock wire from the switch to the alarm system with positive switching.  Have fun
jimmythegreat1
Member - Posts: 35
Posted: December 13, 2002 at 2:15 PM / IP Logged
I really need to know how to hook up the door locks using a 785 prestige alarm people can ya help...
The Van has Keyless entry and you must hit the unlock twice to open all of the doors once for the drivers door are there relays and were and hell how do i hook into them?
Platinum - Posts: 12,488
Posted: December 13, 2002 at 4:58 PM / IP Logged
  • The RED unlock wire goes to the Driver's MOTOR wire ( TAN at the driver's kick panel ) and this connection is a + trigger .
  • Now the second unlock wire from the 785 RED / BLACK go to the WHITE wire in the driver's kick panel .
  • The lock on the 785 GREEN goes to the LIGHT BLUE wire on the van.
  • Check this link out http://www.velocitymotorsport.com/install_notes/Converting_Outputs.jpg and use the NEGATIVE------>POSITIVE OUTPUT diagram.
dcash18
Member - Posts: 38
Posted: December 13, 2002 at 5:39 PM / IP Logged
There is not a chip in the key.  This car uses a resistance type bypass.  The 555L will work.
jimmythegreat1
Member - Posts: 35
Posted: December 16, 2002 at 9:32 AM / IP Logged
Jeff were are these wires located at and do I need relays? or does the 785 handle this for me?
Posted: December 16, 2002 at 12:04 PM / IP Logged
All these wires can be found at the driver's kick panel. You will need a relay for the RED unlock wire so you can convert the current from a (-) to a (+) in order to actuate the priority door lock.
jimmythegreat1
Member - Posts: 35
Posted: December 16, 2002 at 12:15 PM / IP Logged
So Jeff you are saying this is sorta like a toyota or a nissan the groung thrown by the alarm will lock and unlock the doors?
jimmythegreat1
Member - Posts: 35
Posted: December 16, 2002 at 12:22 PM / IP Logged
oops ground not groung
Page of 3
