Trunk release
steezs
Copper - Posts: 172
Posted: November 16, 2005 at 10:11 PM / IP Logged
When your doing trunk release and a car has an electric lock for the trunk, do you need a relay and how do you wire this? If your going to use an actuator can someone give me the connections for the relay in this case too.
the duce
05gt
Silver - Posts: 628
Posted: November 16, 2005 at 10:19 PM / IP Logged
the alarm  brain will more than likely give out a negative trigger for trunk release\
if your cars trunk release wire is negative you don't need a relay
if your cars trunk release wire is positive than you will need relays
cntrylvr79
Silver - Posts: 582
Posted: November 16, 2005 at 10:23 PM / IP Logged
Hard to answer your question without knowing what kind of car and what kind of system you want to put in.  I will do my best.  Assuming your system has a negative trunk output since most of them do.  If your car has a low current trunk relase wire then you can hook the output wire directly to this.  If it's high current negative or positive then you'll need a relay.  For high current negative relay get wired as follows:  85 to trunk release output of alarm.  86 to constant + 12volts. 87 to ground.  Finally 30 to the release wirein the car.  For positive systems change the above set up 87 from ground to +12 volts.  This is how you'd have to wire it up if your using an aftermarket solenoid to pop your trunk.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
