Which bypass?
clsmith
Member - Posts: 34
Posted: November 18, 2005 at 12:17 AM / IP Logged
Installing a keyless entry/remote start on a 1999 Ford F-150. I'm hearing some conflicting stories about which PATS bypass to use: 555f or 555p. The 555p actually lists the 99 F150 but I'm reading that there are some problems getting them to program.
Any suggestions?
cls
redpeppers
Silver - Posts: 483
Posted: November 18, 2005 at 12:37 AM / IP Logged
i have had no problem with the 555p....
Where theres is a wire there's a way.
dare_ds69
Silver - Posts: 419
Posted: November 18, 2005 at 6:51 AM / IP Logged
use the 556u, you loose one key but you don't ever have a problem.
how own your mind, control your life.
MECP certified. always use a DMM
mo12v
Posted: November 18, 2005 at 7:37 AM / IP Logged
I like the OMEGA type:
Ford/Mazda Transponder Interface: PATS1 (IB-F1)
Which bypass? -- posted image.
Or lose a Key:
Which bypass? -- posted image.Which bypass? -- posted image.Universal Transponder Bypass w/ (PASS-4)
MO
Wednesday, November 5, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
