2005 Explorer alarm/remote start
pitoaudiovisual
Copper - Posts: 388
Posted: November 18, 2005 at 9:45 PM / IP Logged
Can anyone please tell me what Direct Fax 1094 is ..  Thanx in advance.
Confidence is the key to any project!!
pitoaudiovisual
Copper - Posts: 388
Posted: November 18, 2005 at 9:49 PM / IP Logged
I have to do a 2005 Explorer and on the paper it says  Can also find at the VSM in the passenger side rear quarter panel below the C pillar.
 What does VSM stands for and what is the C pillar ..  Thanx in advance....
mo12v
Posted: November 18, 2005 at 10:08 PM / IP Logged
# 2..............What are you trying to do?
Ford GEM module wake up - normally closed door trigger
http://www.directechs.com/techtips/pdfs/resources/security/directed_techtips/1094.pdf
MO
mo12v
Posted: November 18, 2005 at 10:23 PM / IP Logged
Vehicle Security Module......Or Central Security Module
MO
NowYaKnow
Gold - Posts: 1,217
Posted: November 19, 2005 at 1:03 PM / IP Logged
No reason to go near the VSM. Let me know what your installing and I will give you some tips.
Mike
pitoaudiovisual
Copper - Posts: 388
Posted: November 20, 2005 at 1:52 PM / IP Logged
i want to install a remote start/ alarm and it says to go to VSM for power locks and trunk release.  any tips would be appreciated
pitoaudiovisual
Copper - Posts: 388
Posted: November 20, 2005 at 1:54 PM / IP Logged
yes
mo12v
Posted: November 20, 2005 at 2:09 PM / IP Logged
Power LockPINK / YELLOWIN DRIVER'S KICK PANEL
Power UnlockPINK/LT GREENIN DRIVER'S KICK PANEL
Negative Pulse Door Locks
Trunk/Hatch Release...( + )....ORANGE / lt. grn or PURPLE / yel .....rear hatch harness
MO
NowYaKnow
Gold - Posts: 1,217
Posted: November 20, 2005 at 5:38 PM / IP Logged
Locks are:
Pink / YELLOW (-) @ Drivers kick panel/door sill harness
Pink/Green (-) @ Drivers kick panel/door sill harness
Hatch Release:
Pink/Orange (-) @ Drivers REAR door sill or
Purple / YELLOW (+) @ Drivers REAR door sill
pitoaudiovisual
Copper - Posts: 388
Posted: November 20, 2005 at 9:23 PM / IP Logged
can you please send me the direct fax #1094.  Try to use link and its not connecting.. Thanx
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
