2000 jeep liberty lock
Mark Buster
Posted: May 08, 2002 at 7:46 PM / IP Logged
I'm attempting to activate this jeep's single wire doorlock system with an Ultrastarter 4500. I was hoping someone might have done this before me and can help. I have tried using the resistors to ground for lock and unlock and nothing happens. I'm not sure if I have the right resistors or not. Am I missing something obvious? I usually don't have too much trouble. anyone!!!            Mark
scss
Member - Posts: 25
Posted: May 08, 2002 at 9:04 PM / IP Logged
Year(s): 2002
Make(s): Jeep
Model(s): Liberty
12 Volt (+)
12ga. Red at ignition harness
Ignition 1
12ga. RED / Blue at same
Ignition 2
Ignition 3
Accessory 1
Accessory 2
Starter
12ga. Yellow at same
Horn
18ga. BLACK/ Red (-) at same
Tachometer
Lights (+)
Lights (-)
18ga. Lt. GREEN/ Orange at same
Brake Lights
Door 1
18ga. Tan (-) (driver door) in Blue connector attached to right side of steering column support
Door 2
18ga. Tan/White (-) (passenger doors) at same
Door 3
Door 4
Interior Lights
18ga. Yellow (-) at light under dash
Trunk/Hatch
18ga. Tan/Black (-) next to door triggers (also for use on LX-1, EX-1 trigger to factory alarm)
Hood Pin
Trunk Release
Lock (switch)
18ga. Pink/Violet (-) @ 1425 -1500 ohm (dual voltage)
Unlock (switch)
Same wire @ 425 -500 ohm
Driver Unlock
Arm (key)
Disarm (key)
18ga. Lt. GREEN/ Orange (-) @ 485 ohm in driver’s door harness (enters just above kick panel)
Arm Input
16ga. ORANGE / Black (M) at back of fuse box in Black connector at top left corner
Disarm Input 1
16ga. Pink/Black (M) at same
Disarm Input 2
16ga. ORANGE / Violet (M) at same
LF Window Up
Jando
Security Specialist
If its a Ford Dont do it
Platinum - Posts: 12,488
Posted: May 09, 2002 at 1:19 AM / IP Logged
Single Wire System. A Negative Pulse Through A 475 Ohm Resistor Will Disarm The Alarm. A Negative Pulse Through A 2 K-Ohm Resistor Will Arm The Alarm. **** Single Wire System. A Negative Pulse Through A 1.4 K-Ohm Resistor Will Lock The Doors. A Negative Pulse Through A 425 Ohm Resistor Will Unlock All The Doors.
markb
Member - Posts: 43
Posted: May 09, 2002 at 11:14 AM / IP Logged
O.k. thanks for the info, I'll give it a whirl                  mark
