94 accord ex parking lights small problem
ricbel
Member - Posts: 10
Posted: December 01, 2005 at 10:06 PM / IP Logged
hey, i just bought a viper 3000, and i when i hooked the parking light flash (RED / black wire with blue plug), it flashes to the front flashers, nicely, but it flashes the rear brake lights, and the dash lights as well. I'd love for it to only flash the turn signals all around, and leave the dash lights and brake lights alone. Is there a any other place I can tap into to do this?
ricbel
Member - Posts: 10
Posted: December 02, 2005 at 12:01 AM / IP Logged
with the first click of the switch the brake lights, front turn signals, and the  gauge(said dash before, sorry) lights come on. If i arm/disarm/set off the alarm those are the lights that come on. I don't like that the gauge and brake lights come on. I was wondering if there was a wire I could tap into to make it flash on the turn signals in the front and back. sorry for the trouble, but it will be much appreciated. Thanks in advance
KarTuneMan
Platinum - Posts: 7,056
Posted: December 02, 2005 at 12:49 AM / IP Logged
The parking light flash IS connected to the dash lights on this car........
You have it connected properly......
ricbel
Member - Posts: 10
Posted: December 03, 2005 at 2:00 AM / IP Logged
Sorry to sound annoying, but is there any other wire I could tap in to that wouldn't flash the gauge lights?
05gt
Silver - Posts: 628
Posted: December 03, 2005 at 2:03 AM / IP Logged
nope because the dash lights come on whenever the headlights are on and if the parklights are on
you could turn the dimmer switch down so the dash lights don't light up
ricbel
Member - Posts: 10
Posted: December 03, 2005 at 2:27 AM / IP Logged
oh, ok thanks. Now I'm wondering if i could hook up the horn honk feature without getting another relay. Is the horn driven by a relay or is it just switch. my alarm says it can put out a negative 200mA output for this, is it possible to hook it up without buying a relay? I don't really care for the horn honk, so if I have to get a relay I just wont hook it up. Thank's in advance.
cntrylvr79
Silver - Posts: 582
Posted: December 03, 2005 at 7:18 PM / IP Logged
You won't need a relay for the horn honk.  Just take the trigger wire and hook it up to the horn trigger at the steering column.
Cause I'm So white and nerdy...
First Class Certi-fried installer
rmeehan
Posted: December 04, 2005 at 5:01 PM / IP Logged
actually there is another wire u can use its in the ignition harness its a blue wire it reads negative and just make sure u switch the brain to negative parking lights and ur golden
Hornshockey
Silver - Posts: 520
Posted: December 05, 2005 at 1:37 AM / IP Logged
if you want the lights to flash like your four-ways (hazards) you'll need to get your turn signal wires from the flasher unit under the dash and diode isolate each to prevent all of them from flashing when you use your turn signals. It's really a big pain and not worth the trouble in most cases.
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
