Parking Lights for 2005 Durango
88mr2
Posted: December 03, 2005 at 10:45 PM / IP Logged
Hi, I have 2005 Dodge Durango which I am installing a Remote starter. The durango has the Automatic Headlight feature. What wires on do I use to enable the parking lights for the remote starter?
infinkc
Copper - Posts: 438
Posted: December 03, 2005 at 10:58 PM / IP Logged
Parking Lights+ pink/red (L), WHITE/ orange (R) +   fuse box, black plug, pins 6 and 5
Parking Lights- pink/red   -   headlight switch
Notes: Parking lights are negative trigger thru a 1100 ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.
There are 10 types of people in the world, ones that understand binary and ones that dont.
88mr2
Posted: December 03, 2005 at 11:23 PM / IP Logged
Thanks infinkc, I do not understand what you meen by "rest resistance"?
Mike M2
Platinum - Posts: 2,652
Posted: December 04, 2005 at 7:34 AM / IP Logged
It means you must wire a relay 5 wire style so that when you activate the alarm it doesn't feed back to the switch side of the wire. It's easier to just use the positve and diode isolate the left and right sides....
Mike M2
Tech Manager
CS Dealer Services
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
