Hazard Lamps
rrspyder
Member - Posts: 26
Posted: December 17, 2002 at 7:21 PM / IP Logged
Is it possible to tie the light flashing output of my VIpver V790xv into the hazard lights  instead of the light switch on my 2002 Mustang GT? I do not like having all of the interior lights flash including my gauges and my stereo receiver when I arm the car. Just seems like a bunch of unneeded flashing to me. I would just like the hazard lights to flash if at all possible. Also any chance that someone knows where the wire is for this if it is possible?
Thanks,
Kyle
Platinum - Posts: 12,488
Posted: December 18, 2002 at 12:42 AM / IP Logged
Never done the hazard light, but they should be accessible through the actual switch . Take the switch out and probe the wire that tests (+) when the 4 way flashers are on.
rrspyder
Member - Posts: 26
Posted: December 18, 2002 at 8:56 AM / IP Logged
Alright, thanks Ill try that. Would I need any type of relay to tap into the wire or just straight from the alarm?
Thanks,
Kyle
Posted: December 18, 2002 at 9:39 AM / IP Logged
You should be able to go straight from the alarm to the switch.
rrspyder
Member - Posts: 26
Posted: December 18, 2002 at 10:08 AM / IP Logged
Alright, thanks. Also, is it ok if I have to ouput the flash wire to each component wire seperately such as connect the flash ouput to front left turn wire/ front right turn wire, etc.. From what I can tell it looks like when the switch is pushed it supplies voltage to each individual wire such as front right turn/ front left turn lights, etc..
Thanks,
Kyle
