2005 chevy 1/2 ton PU remote start
woodn01
Member - Posts: 27
Posted: December 15, 2005 at 11:14 PM / IP Logged
We just installed a viper 771 2-way RS unit on another installer's 2005 chevy 1/2 ton P/U. everything works fine but the airbag light is staying on. we have both ignition wires powered. we just jumpered off ignition 1 to ignition 2 but diode isolated them. should i use a relay instead? we can't get the light to go off even with a code reader. what is wrong?
05gt
Silver - Posts: 628
Posted: December 15, 2005 at 11:46 PM / IP Logged
did you power up the accessory wire(s)
redpeppers
Silver - Posts: 483
Posted: December 16, 2005 at 12:11 AM / IP Logged
i wouldnt suggest diode isolating those wires....also use a relay.
Where theres is a wire there's a way.
extreme1
Silver - Posts: 1,070
Posted: December 16, 2005 at 9:53 AM / IP Logged
771 Has all the ign and acc outputs you need.
I would have it scanned at GM and find out what the airbag code is.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
woodn01
Member - Posts: 27
Posted: December 16, 2005 at 10:30 AM / IP Logged
we powered up the first and second ignition and the first and second accessory wires. we used a code reader on it but we can try another code reader. has anyone came across this problem yet?
JWorm
Platinum - Posts: 2,208
Posted: December 16, 2005 at 4:29 PM / IP Logged
You would need some really big diodes to be able to power two ignitions wires with 1 output.
99% of the time you don't need the brown acc. wire.
Connect as follows.
CAR WIRING/ REMOTE START WIRING
pink --> pink
pink/white --> white
orange --> orange
Also, make sure the pink/white wire is still programmed as an ignition output
kgerry
Platinum - Posts: 3,455
Posted: December 16, 2005 at 4:47 PM / IP Logged
and make sure you have the Right white wire... often there are 2 whites ate the column
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
wrxsti161
Copper - Posts: 62
Posted: December 16, 2005 at 6:04 PM / IP Logged
Yes, I agree with JWORM. I have not had the airbag light come on, but I have had the check engine light come on.  I dont hook up the brown acc. wire. so you can freely use pink and pink/white.
Platinum - Posts: 12,488
Posted: December 16, 2005 at 6:21 PM / IP Logged
Never had any problems with any of the Chevy PU's yet. The AIR BAG light will be because of an ignition wire. Relay isolate the 2nd IGN and your problem will go away. There's a reason why the manufacturer has the IGN on separate wires.
old_skool
Member - Posts: 15
Posted: December 16, 2005 at 6:48 PM / IP Logged
You may want to try rerouting the 12V constant to a different location. A friend of mine had this problem  on a Chevy  truck and the explanation was that the PCM monitors the voltage on this wire (haven't confirmed if this is true or not) and the voltage drop from the alarm causes the problem. However this was one of his symptoms and then the instrument panel started tripping out.
Monday, April 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
