Astrostart 5204, 2006 Silverado Duramax
tbalt
Posted: December 18, 2005 at 10:01 PM / IP Logged
I just installed a 5204 Astrostart in my 2006 Silverado Duramax and it seems to be working correct.
My questions are:
-    When the "Wait to Start" light is on for the glow plugs is it a + or - signal on my truck?
-    And second I'm trying to hook up a Directed  556T timer to the Astrostart 5204 P10 connection. The timer module sends a (-) signal to the starter, but the installation manual from Astrostart does not give a wiring diragram for the connections to the P10 connector.   Can somebody help me through this?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 19, 2005 at 1:40 AM / IP Logged
You do not need the DEI part.........set your unit for NEG(-) glow plug found behind the cluster. DK.blue.,
Don't mix DEI crap.....with astro...good stuff..........K..!
For this truck you do NOT need the P-10 connector
tbalt
Posted: December 19, 2005 at 9:23 AM / IP Logged
I do need the P10 plug if I want to hook up the timer.
I am out of range with the remote start and want it to start with the timer I have. Does anybody know the wiring pinout of the P10 plug on a Astrostart 5204.
KarTuneMan
Posted: December 19, 2005 at 12:15 PM / IP Logged
I see....use the astro RST-2...and just plug it in!
to use the DEI piece, youll need astro part # 310-903-271-01 its the harness that plugs into the p10 The pin is the #4 that gets the neg trigger (left to right)
Look at page 21 of the install manual
tbalt
Posted: December 19, 2005 at 3:07 PM / IP Logged
Do you know where I can get the harness astro part # 310-903-271-01?
KarTuneMan
Posted: December 19, 2005 at 3:12 PM / IP Logged
The shop you got the 5204 from should be able to get you one
sparkie
Platinum - Posts: 2,061
Posted: December 19, 2005 at 8:00 PM / IP Logged
The dark blue wait to start wire at the cluster is in position A2 and is negative.
sparky
