2003 explorer not starting
Simplemitch
Copper - Posts: 68
Posted: December 19, 2005 at 9:31 AM / IP Logged
just put a unit in a 2003 explorer (4door w/ V8) and the remote start wont work. The vehicle has the wire colors similar to an '04
battery ---yellow
ignition---RED / lt. green
starter-----red
accessory--dk. green / lt. green
I havent hooked up the accessory wire (didnt have the right color info when i was working on it) but I would assume that it would still start without it..no? I'm usin a DEI 555F bypass and it's getting power when starter activates.  Any suggestions?
Mitchell Whitney, Installer/technician
Mainstreet A/V
Simplemitch
Copper - Posts: 68
Posted: December 19, 2005 at 9:39 AM / IP Logged
oh, and i forgot to mention that i can't rule out a defective bypass, because i didnt have time to try the remote start with a key in the ignition.....
Mainstreet A/V
mistahiggs
Member - Posts: 29
Posted: December 19, 2005 at 10:24 AM / IP Logged
what model RS are you using, and is there no response from the car when remote started? or does it try to start and then die after a second?   and i'm pretty sure you need the accessory wire hooked up
higgs
ruse
Member - Posts: 11
Posted: December 19, 2005 at 9:49 PM / IP Logged
Yes Acc. wire does need to be connected. It does more then just turn on the blower motor. Other possibilty is PATS bypass.
Ford Authorized Accessory Installer/Dealer
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
