2001 Ford F150 Remote Start
ryman03
Posted: December 23, 2005 at 6:41 PM / IP Logged
I recently installed a remote start on my F150.  The key will no longer start the vehicle unless the pass4 tronsponder module is disconnected and I do not understand the problem.  The remote start works fine and it will drive when remote started first.  But the key does not work in the ignition unless remotely started first.  Any comments are greatly appreciated.
Thank you for any interest
RyMan
mo12v
Posted: December 23, 2005 at 6:50 PM / IP Logged
How do you have the PASS 4 hooked up?  Is it Powered Up when the Key is turned ON?
MO
ryman03
Posted: December 24, 2005 at 9:06 AM / IP Logged
The pass4 has an antenna loop which is hooked up around the ignition.  It also has three wires coming from it.
Green- key sense inhibit- I hooked it to a black and pink wire right on ignition
Red (+)12 volts- I hooked up to the same 12 volt supply as the remote start module
Blue/white (-)Ignition-  I grounded
The remote start works fine and starts the vehicle and then you can put the key in but you have to use the remote starter in order to operate the vehicle.  Thenk you for your concern any more comments or suggestions would be greatly appreciated.
RyMan
NowYaKnow
Gold - Posts: 1,217
Posted: December 24, 2005 at 9:51 AM / IP Logged
Its because you have your bypass on at all times. You don't want to ground the blue/white wire. You want to run it to your remote starters (-) status output / active output / or ignition 3 negative output.
Mike
ryman03
Posted: December 24, 2005 at 1:31 PM / IP Logged
NowYaKnow,
Thank you very much.  I really appreciate the assistance.  I just tried to hook it up and everything is working great now.  Happy holidays to you and your family.
RyMan
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
