Viper 790XV progressive door unlock
blurr
Posted: December 26, 2005 at 6:01 PM / IP Logged
I have a viper 790xv installed that I recently deleted all transmitters and then reprogrammed the remotes. When I did this, I lost my progressive door unlock. Can this be reprogrammed using the valet button or will I have to take it back to the installer?
Mike M2
Platinum - Posts: 2,652
Posted: December 26, 2005 at 8:46 PM / IP Logged
There is no programming to turn 2 stage unlock on or off. It simply works on the second press of the disarm button, sending a pulse out on the lt. blue wire on the secondary harness. Was your 2nd stage of unlock on the same button as disarm? Did you reprogram your remote to the default setting(feature 1)?
Mike M2
Tech Manager
CS Dealer Services
blurr
Posted: December 27, 2005 at 9:13 AM / IP Logged
Yes, the second stage of unlock was on the disarm button. When I reprogrammed the remotes, I used channel 8 which I was told to do when using a DEI 472V remote. Thanks for your response!
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
