97 monte carlo, Avistart 3200
duoproductionx
Copper - Posts: 49
Posted: December 27, 2005 at 2:02 PM / IP Logged
alright label me n00b of the year, first time doing an 'alarm install' the only function i plan to use on it is the keyless entry, on an AVISTART 3200(until i get the passlock override for the remote starter part), i have all wiring diagrams for the unit however, few questions. what kind of method do the lock switch use? its got 4 wires blue orange white and something else if i remember correctly. other main question, where are you supposed to mount the fuseblock looking ends where you wiring the inputs and outputs? much appreachated if anyone can help, flame me if this is to dumb of a question! my expertise lies elsewhere.
97 Monte Carlo
CDA-9885, PZI Crunch 5 channel,12in MB Quart Premium.
jayyzr
Copper - Posts: 114
Posted: December 27, 2005 at 2:29 PM / IP Logged
as for the door locks it should be  the Light Blue to lock and white to unlock (requires a + trigger) ALWAYS TEST WIRES w/ a Digital Multimeter
 POWER LOCK LIGHT BLUE (TYPE A)  IN DRIVERS KICK PANEL
 POWER UNLOCK WHITE (TYPE A)  IN DRIVERS KICK PANEL
Taking It 1 Wire @ A Time...
duoproductionx
Copper - Posts: 49
Posted: December 27, 2005 at 4:18 PM / IP Logged
thanks for the info, my haynes manual says the locks flip on a negative pulse, ill have to get a decent digi meter lol
97 Monte Carlo
duoproductionx
Copper - Posts: 49
Posted: December 28, 2005 at 7:10 PM / IP Logged
what is type A wire? theres about 4 light blue wires down there only one white
97 Monte Carlo
mo12v
Posted: December 28, 2005 at 7:35 PM / IP Logged
Positive Pulse
Power LockL BLUE  +20 PIN CONNECTOR LOW
Power UnlockWHITE  +IN DRIVER KICK PANEL
MO
duoproductionx
Copper - Posts: 49
Posted: December 28, 2005 at 8:34 PM / IP Logged
ok i figured out which was which, hooked it up to the fuse looking harness, got the units power and ground hooked up, im trying to program it just for the locks, it just blinks the LED when i push the "arm" button
and makes a series of clicking noises when i press the "disarm" button
97 Monte Carlo
jayyzr
Copper - Posts: 114
Posted: December 28, 2005 at 9:14 PM / IP Logged
so you have the systems Lock  & unlock (-) Pulse wires hooked up to a relay to provide a Positive trigger or you just connected them w/out a relay???
duoproductionx
Copper - Posts: 49
Posted: December 28, 2005 at 9:19 PM / IP Logged
theyre hooked up to a relay to make a positive trigger
97 Monte Carlo
jayyzr
Copper - Posts: 114
Posted: December 28, 2005 at 9:44 PM / IP Logged
I would just unplug the unit make sure you have a nice clean ground( no paint or rust) and 2x chk lock/unlock wires w/ ur DMM  you should have a 0 then when triggered goes to a positive, chk  the wiring of ur Relay,
duoproductionx
Copper - Posts: 49
i know its the right wires, i dont have a digimeter so i went with the cut and pray option, i cut the white and the driver door could no longer unlock and went i did the light blue it couldnt lock either, passenger side still works thankfully
97 Monte Carlo
