chrysler van /autopage 855LCD problems
simonmai
Member - Posts: 9
Posted: January 03, 2006 at 11:43 AM / IP Logged
Hello everyone,Happy new year to all of you.
I installed autopage 855 lcd and 555C transponder bypass in my 2002 chryslerT&C with ,everythings work great but one big problem is...I can't not move the transmission shifter to drive the car even I tried to start the car with the facory key.Dose anyone knows whats causing it???is there any Ground related to that problem.Please help me out.Thanks
simonmai
Platinum - Posts: 12,488
Posted: January 03, 2006 at 9:44 PM / IP Logged
Make sure that you did not cut the brake wire. Test the brake wire to see if your getting 12 volts. Also, I found that the shifter lever on the 2001+ vans are finicky. Make sure that your not pulling too much while pulling down on the shifter handle, otherwise it will not move ( as you described ).
