2004 civic remote start
mobilecustoms
Silver - Posts: 397
Posted: January 09, 2006 at 9:24 PM / IP Logged
on a 2004 civic lx. the owner wants a dual stage unlock installed on a Valet 562t. Which wire is needed to be cut and a relay installed? How does the relay get wired? Where is the wire in the car that needs to be cut for the drivers door priority located?
mo12v
Posted: January 09, 2006 at 9:33 PM / IP Logged
Drv Door UnlockYELLOW /GREENAT UNDER DASH FUSE/RELAY BOX
Cut  UNLOCK Wire in Half.
One Half goes to SWITCH
One Half goes to ACTUATOR
SPDT Relay:
PIN 87 =  12 Volts ( + ) Constant
PIN 87a =  wire from Door Lock Switch
PIN 30 =  wire to Actuator
PIN 85 = Negative Lock Output from Alarm
PIN 86 = Constant 12 volt ( + )
MO
mobilecustoms
Silver - Posts: 397
Posted: January 09, 2006 at 9:43 PM / IP Logged
does it matter if 87a and 30 are reversed?
mo12v
Posted: January 09, 2006 at 9:46 PM / IP Logged
YES.........
Wire just like posted or Damage can result to Switch
MO
mobilecustoms
Silver - Posts: 397
Posted: January 09, 2006 at 9:48 PM / IP Logged
ok thanks a lot
Thursday, January 29, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
