ct-3200 remote starter issues 1988 olds
wheelie81
Posted: January 09, 2006 at 11:35 PM / IP Logged
1988 olds delta 88 all wires are correct from remote to harness but when remote starting the engine will crank 8 times and stop with out starting,it will start with key,but not by remote it is like the ignition wire is incorrect but to all wiring specs it is correct pink+from what i can tell is the remote is not telling the coils to fire the fuel, is their a second ignition wire?
kohara73
Copper - Posts: 192
Posted: January 10, 2006 at 8:43 AM / IP Logged
Ive checked 2 sources and only see the one ignition you spoke of.  Did you program tach?  Are you sure you didn't hook up ACC from your RS to IGN on your car?  See if it remote starts with key ON(RUN).  If it does, your igniton is not getting power during RS.
Keith
