How to wire clutch bypass for dodge neon
jacbri
Member - Posts: 7
Posted: January 13, 2006 at 12:54 AM / IP Logged
Ok this is the last thing left on the compusar 2W900FM-AS (manual). I desperately want this done because it has taken 3 of my days so far.
The clutch bypass wire on the neon is a yellow/red I believe. From the Alarm I will be using CN2-3 which is a green wire (-) ignition. I was told from a dealer this green wire needs to be used because CN2-2 is being used. ANy help would be appreciated. There is an internal relay.
05gt
Silver - Posts: 628
Posted: January 13, 2006 at 1:24 AM / IP Logged
just use the (-) starter wire from the second harness, this is what I used
and wire in a relay
jacbri
Member - Posts: 7
Posted: January 13, 2006 at 2:38 AM / IP Logged
and wire in a relay
how do you wire the relay?
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
