Window modules on 05 Chevy Silverado
x-performance
Member - Posts: 11
Posted: January 14, 2006 at 2:06 AM / IP Logged
Installed window modules by the directions and windows will not roll up. I've heard that you can't install them the regular way on the new chevys. Any help is appreciated.
thanks.
mo12v
Posted: January 14, 2006 at 8:13 AM / IP Logged
Window Up*Dr Front\ BLUE
PasFront\ BLUE
DrRear\ BLUE
PasRear\BLUE @ Each Switch Due to Data Link
Window Down*DrFront/ BROWN
PasFront/ BROWN
DrRear/ BROWN
PasRear/BROWN *
* Front Windows ......Reversal Rest At Positive Type Window Circuit
 *Rear Windows .....Reversal Rest At Ground Type Window Circuit
MO
mike swanson
Copper - Posts: 290
Posted: January 14, 2006 at 12:11 PM / IP Logged
You will need 4 relays and this get so crazy that I decided not to do these trucks it also makes the window roll very slow with the factory contol. We got it to work but the slow roll wasnt worth it.
So if you want to SLOW your ROLL then its ok
x-performance
Member - Posts: 11
Posted: January 15, 2006 at 4:34 PM / IP Logged
so is it easier to do with 2 relays to each window using Reversal polarity method or can it be done with a window module some how?
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
