viper car starter, 2000 lumina
spartyman
Posted: January 22, 2006 at 4:52 PM / IP Logged
I had a viper car starter model 130XV installed in  my 2000 chevy lumina and now my tail lights will not go off unless i pull the fuse, whats going on?
Tony Seefeld
indyaudioguy
Member - Posts: 13
Posted: January 22, 2006 at 5:30 PM / IP Logged
There could be several reasons for that.  If you paid for the installation, you should seek the installer's help, of course.  If you are troubleshooting youself, you may wish to check the parking light output from your Viper to see if it is on all the time.  (Whether it is a positive or a negative output, it might be 'stuck' on.)  Just disconnect that lead to see if your problem goes away if you are unsure.
Good Luck
Anderson Electronics, Inc.
Platinum - Posts: 12,488
Posted: January 22, 2006 at 5:53 PM / IP Logged
When did this start happening ? Right after the installation ?
JWorm
Platinum - Posts: 2,208
Posted: January 22, 2006 at 6:01 PM / IP Logged
Tail lights? Do you mean parking lights or brake lights? I'm guessing brake lights. One possibilty is something applying pressure to the brake switch under the dash.
And what fuse did you pull? A fuse in the car or a fuse from the remote starter?
feenal
Copper - Posts: 54
Posted: January 22, 2006 at 8:01 PM / IP Logged
I would say the brake switch got pulled out of its bracket causing the brake lights to stay on, follow the wire from the module for brake imput if you don't know where this switch is.
another-kelly
Silver - Posts: 618
had a guy come a few days after putiing in a remote start and complained that i screwed up and his brake lights stayed on all the time. turns out the day after i did the RS, he took it somewhere else to put on a trailer brake contoller. they took the brake switch out and didn't put it back in all the way. he apologized. at any rate, if it's the brake lights you might check the switch on the pedal.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
