paslock interface
wlfgnggtr
Posted: January 26, 2006 at 8:10 AM / IP Logged
Does anyone know the proper procedure for interfacing the gm paslock when installing a remote start on a 99 Pontiac Grand Am?
tjdurham
Copper - Posts: 180
Posted: January 26, 2006 at 8:42 AM / IP Logged
what kind of bypass do you have ?
the best one for this car is DEI555L you have to take the radio out to access the ignition switch wires
tj
Platinum - Posts: 12,488
Posted: January 26, 2006 at 9:36 AM / IP Logged
There are about 6 different modules & 3 different methods for bypassing the Passlock II system on the Grand Am. The easiest way is to purchase a bypass module that will interface and bypass the system without the use of relays and resistors. They will range in price between $ 20 - $ 50 depending on the place that you purchase from.
wlfgnggtr
Posted: January 26, 2006 at 6:52 PM / IP Logged
Thanks for the help. The DEI 555L is what I was thinking about, that was what was recomended in the manual with the remote start. Thanks again...
                           Todd
