RS 996a on a 2002 explorer sport trac
nattopdog
Member - Posts: 13
Posted: January 29, 2006 at 1:12 PM / IP Logged
I recently installed a RS on my sport trac. Everything works fine. but it only unlocks if the vehichle is started or has just been shut down. It will disarm and it show on the lcd to be unlocked but it will not unlock. If you start the vehicle it works everytime. And it works within about 2 minutes of shutting the engine off. Any help would be appreciated.
it is a 996a prestige alarm.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 29, 2006 at 1:40 PM / IP Logged
dk.GREEN/ purple is the disarm, if you do a "pulse before" on this wire it will wake up the BCM. The wire is in the drivers kick. NEG(-) trigger
