2002 grand am security light
stiney
Member - Posts: 7
Posted: February 11, 2006 at 5:57 PM / IP Logged
I just installed a code alarm 425/535 with a plxr bypass module on a 2002 grand am gt . Everything works like it should except the next day he said his security light stays on solid when the vehicle is running, with or without the remote start. I didn't hook up the key sense wire from the plxr. Is it possible I need to replace the plxr? Any suggestions would be helpful.
mo12v
Posted: February 11, 2006 at 6:27 PM / IP Logged
I would make sure both Ignition wires are being powered with Key & R/S
MO
stiney
Member - Posts: 7
Posted: February 27, 2006 at 1:39 PM / IP Logged
Both ignition wires are being powered with the key and r/s. Someone said to try disconnecting the battery to reset the system. I guess I'll try another bypass module too. Any more suggestions?
au5599
Copper - Posts: 95
Posted: March 01, 2006 at 7:57 PM / IP Logged
The PLXR is fine for that car. Hook up the key sense wire also. Reprogram the interface and make sure it is set to passlock II. Make sure you have it getting 12v and  ignition.
You can also use the gmbp interface.
stiney
Member - Posts: 7
Posted: March 02, 2006 at 12:42 PM / IP Logged
Any idea what color the key sense wire is?
xtremej
Gold - Posts: 1,440
Posted: March 02, 2006 at 12:56 PM / IP Logged
Lt.green can be found @ the bcm pass foot well.
au5599
Copper - Posts: 95
Posted: March 02, 2006 at 4:30 PM / IP Logged
light green at ignition harness.
Street Dreams Car Club
93 GRAND CARAVAN SE / Astro
Team New York SS3-4 06 & SM3-4 07 DB Drag World Finals
2003 Chevy Suburban LT / 98 GTP
xtremej
Gold - Posts: 1,440
Posted: March 02, 2006 at 4:41 PM / IP Logged
or the ignition harness:)
