2004 Chevy Malibu 457gw?
dadz
Member - Posts: 33
Posted: February 20, 2006 at 2:33 PM / IP Logged
My supplier says a 457 gw will work with a 04 malibu, but I have tried several times to program it unsuccesfully. DEI only lists 556U to work with these anybody have hands on experience that knows?
Ravendarat
Platinum - Posts: 2,806
Posted: February 20, 2006 at 4:10 PM / IP Logged
Ya, that module works fine but I cant remember if it did door locks and what not or if it was only for the antitheft system. I do know FOR SURE that it will work for the bypass
dadz
Member - Posts: 33
Posted: February 20, 2006 at 4:17 PM / IP Logged
I tried programming it again without luck. According to the instructions I am supposed to get the led to flash then once the key is inserted while holding in programming button, I can't get the leds to flash..Any ideas. I've used these bypass before and never had this problem.
Thanks again
mo12v
Posted: February 20, 2006 at 5:51 PM / IP Logged
Thanks again
Press & Hold Programming Switch WHILE Inserting Harness
LED should Iluminate
Keep Button Pressed while Turning Ignition to ON
Release Programming Button
LED should be Flashing rapidly
Start Engine
LED should turn OFF
Be sure to have ALL connnections of R / S done & TACH Learned before Programming
MO
another-kelly
Silver - Posts: 618
Posted: February 20, 2006 at 9:43 PM / IP Logged
CHEVROLET / MALIBU / 2004 / Remote Start
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
PASS-Key III+
Part #: 556UW
Door Lock Interface
Required:
Yes
Type:
Multiplex
Part #: 456LW
457G won't do the bypass. it has PK3+.
Ravendarat
Posted: February 20, 2006 at 10:27 PM / IP Logged
Im telling ya that this Module does work, I have done it more than once in my shop, the key to programing is to hold the Button WHILE PLUGGING TO MODULE IN. Thats the mistake that most people make.
Ravendarat
Posted: February 20, 2006 at 10:29 PM / IP Logged
oh shhh, my bad I was thinking 03, another kelly is right here, you are gonna have to use the 556U or the 456L on this sucker
