4 windows up with 530t
bdl666
Silver - Posts: 330
Posted: February 21, 2006 at 4:48 PM / IP Logged
When I bought it I was told that this unit could do 2 windows up and down or 4 one way.
I can't find a way to make it happen I can wire it for 2 windows up and down just fine, but not 4 one way.  And the worst thing is that the shop where I got it charge me $90 for the unit.
mo12v
Posted: February 21, 2006 at 6:21 PM / IP Logged
Wasn't aware the 530t was able to do 4 one way
MO
cntrylvr79
Silver - Posts: 582
Posted: February 21, 2006 at 9:40 PM / IP Logged
As far as I know it can't do 4 1 way only 2 up and down
Cause I'm So white and nerdy...
First Class Certi-fried installer
bdl666
Silver - Posts: 330
Posted: February 21, 2006 at 10:19 PM / IP Logged
I'll go back to the shop where I got it and have them show me how they make the 530t do 4 windows one way.  And get my money back I found it at another shop for $60 .
iceohio
Member - Posts: 37
Posted: February 21, 2006 at 11:28 PM / IP Logged
Not familiar with that particular unit, but most have a wire that needs to be cut to switch from 2W U/D to 4W U.
I'd imagine that would be pretty clear in the docs though   :(
Joseph
iceohio
Member - Posts: 37
Posted: February 21, 2006 at 11:31 PM / IP Logged
Ewps...
Didn't realize this message was so old...
iceohio
Member - Posts: 37
Posted: February 21, 2006 at 11:32 PM / IP Logged
Very odd.  The dates changed to 2002, then back...  So disregard my last msg.
swamprat323
Gold - Posts: 1,335
Posted: February 22, 2006 at 9:12 AM / IP Logged
do a search on here. i read it can be done and i read it cant be done.
JWorm
Platinum - Posts: 2,208
Posted: February 22, 2006 at 2:10 PM / IP Logged
I believe you wire the "Down" wires on the window module to the"Up" rear window wires. You'll then need to connect the ground when armed wire from the alarm to the (-) up and down triggers of the 530T.
Tuesday, September 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
