disabling a factory theft system
dreamSdime
Posted: February 24, 2006 at 11:39 PM / IP Logged
I have a 1998 oldsmobile cutlass with a factory anti-theft system. It has a little under 200,000 miles on it. The problem i am having ids the tumblers in the ignition are wearing out and i don't have the money to get a new one. I was wondering how, if you could, disable the anti-theft system permanently.
knowledge is worthless until you can use it
mrcllusb
Copper - Posts: 489
Posted: February 25, 2006 at 3:31 AM / IP Logged
You can get a tumbler from a junk yard for pretty cheap..Secondly,do you have a chip key?
"ole blake"
sparkie
Platinum - Posts: 2,061
Posted: February 25, 2006 at 12:54 PM / IP Logged
If your car has VATS (resistor chip in the key) then you can find the two thin white wires in the ignition harness and cut them. Wire in a resistor of the same value across the car side (not key side) of the two cut wires to permanently disable the system. The two white wires are usually inside orange or black insulation and may appear as one wire until they terminate at a large connector along with all the other wires.
sparky
Mike M2
Platinum - Posts: 2,652
Posted: February 26, 2006 at 8:36 AM / IP Logged
Heck, the tumbler new is under 30 bucks...
Mike M2
Tech Manager
CS Dealer Services
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
