alarm lock and unlock
elchapin
Member - Posts: 13
Posted: April 04, 2006 at 3:44 PM / IP Logged
I was wondering if anyone can help I am having troublw with my alarm it will no longer lock and unlock my power locks. I checked my power locks and they are fine I wanted to know if there was a way on checking the alarm outputs for lock and unlock. Also would there be a way for me to make it lock and unlock if the outputs are burned out. Last question this is for another car I  wanted to know if there was a way to make my windows roll down with the unlock feature and roll up with the lock feature?
erh
mo12v
Posted: April 04, 2006 at 4:20 PM / IP Logged
Not knowing more info
Year, Make & Model
Brand & Model of Alarm
makes it difficult to give good answers.
You can check the Output of your Alarm with a Meter.
Check the workings of the Door Lock Wiring needs more Info.  They could be 12 Volt + , - 5 Wire reversal, Resistor, etc.
On your Windows:
There are a varity of Modules available to accomplish this.
MO
elchapin
Member - Posts: 13
Posted: April 04, 2006 at 4:24 PM / IP Logged
well the alarm says postive lock negative lock that is why I assumed it would easier to just state the question like that.
erh
mo12v
Posted: April 04, 2006 at 4:29 PM / IP Logged
A lot of Units have that ability.
You probably need give the Brand & Model
Also car it is installed into
MO
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
