DEI 528t Triggers?
mmh1
Copper - Posts: 120
Posted: April 10, 2006 at 8:21 PM / IP Logged
Hi,
I have a dei 528T pulse timer and would like to know more about how to trigger it to connect a circuit with my LED footwell lights on to turn on when the alkarm is disarmed for 90secs.
My alarm has a constant negative output when armed which goes to zero when disarmed. It also has an unused immobiliser circuit that can break a connection up to 10amps.
Does the 528T have a facilty to be triggered by a constant source which goes to zero?
Or can it be triggered by a source that goes from zero to a constant ground (using the immobiliser wires to disconnect >>> connect a wire going to a ground source)
Also what happens after triggering does the circuit connect for the set timed duration and then disconnects regardless of a still present trigger input which is still constant?
Thanks,
swamprat323
Gold - Posts: 1,335
Posted: April 10, 2006 at 9:09 PM / IP Logged
you can use the unlock wire from the alarm to pulse the 528T
doibuy
Copper - Posts: 177
Posted: April 10, 2006 at 9:39 PM / IP Logged
Swamprat323 is right, use the unlock pulse from your alarm to trigger the 528t.  This relay works like a normal relay, meaning it only needs a momentary pulse to trigger, but will stay latched for the amount of time it is set up for.  You'll just have to adjust the set screw to increase the time.
mmh1
Copper - Posts: 120
Posted: April 11, 2006 at 5:20 AM / IP Logged
Hi Guys,
That's the problem my alarm does not have any onboard locking controls to pulse the 528T all it has is a constant negative out when armed. Also the unused immobiliser circuit interrupt.
Any ideas???
Twelvoltz
Platinum - Posts: 2,384
Posted: April 11, 2006 at 8:29 AM / IP Logged
What is the make/model of your system? There are not many that do not have door lock outputs.
mmh1
Copper - Posts: 120
Posted: April 11, 2006 at 5:34 PM / IP Logged
https://img51.imageshack.us/img51/7470/alarmdiagram1ao.gif
Click the link then click on image to enlarge.
Here's the instructions from the alarm, which may help clarify the system.
Thanks, Mo
Twelvoltz
Posted: April 12, 2006 at 9:07 AM / IP Logged
According to the diagram there is a BROWN / white that is remote control activated (presumably a channel 2 output). You could use this wire to activate the pulse timer anytime you want the lights to come on.
mmh1
Copper - Posts: 120
Posted: April 12, 2006 at 10:50 AM / IP Logged
Hi,
The BROWN / white is attached to the ultrasonic sensors (-ve power supply).
The keyfob only has 2 buttons:
Button 1: arm/disarm or arm press again quickly exclude interior ultrasonic sensors
Button 2: purely as a panic button (not programmable)
Thanks,
Mo
swamprat323
Gold - Posts: 1,335
Posted: April 12, 2006 at 11:57 AM / IP Logged
just use the the parking output then. but this will make it coem on also when armed.
mmh1
Copper - Posts: 120
Posted: April 12, 2006 at 12:25 PM / IP Logged
That would set off the alarm when armed, due to a negative being supplied to the dome light.
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
