05 Colbolt Disarm Wire
newinstaller
Copper - Posts: 160
Posted: April 12, 2006 at 11:25 PM / IP Logged
Hi,
Any info on the 05 Colbolt Disarm Wire?
Everything else is done
dea,can
Copper - Posts: 284
Posted: April 13, 2006 at 12:27 AM / IP Logged
Arm/Disarm factory remote only
dragon
Chris Luongo
Platinum - Posts: 3,746
Posted: April 13, 2006 at 8:38 AM / IP Logged
dea,can is correct.
--The only way to arm the factory alarm is to lock the doors using the factory remote.
--The only TWO ways to disarm the alarm are to:
A. Unlock the doors with the factory remote, or
B. Turn on the ignition.
sparkie
Platinum - Posts: 2,061
Posted: April 13, 2006 at 5:17 PM / IP Logged
Bypasskit.com will soon have a module out that will control the locks and factory alarm on these cars. Until then you have to use the factory remote to arm and disarm. If you can't wait, there are modules designed to wire directly into the factory remote and trigger it's lock and unlock buttons as well as provide it with a 3 volt power source.
sparky
newinstaller
Copper - Posts: 160
Posted: April 17, 2006 at 11:45 AM / IP Logged
What about using the Compustar feature
Unlock before start lock after start?
Would that work?
xtremej
Gold - Posts: 1,440
Posted: April 17, 2006 at 12:10 PM / IP Logged
My memory is pretty bad but I think that it will. I installed an Ultra start and it to has that feature. I'm about 90% sure it worked on the last cobalt we did.
sparkie
Posted: April 17, 2006 at 8:26 PM / IP Logged
No it won't work. The only way to disarm the factory alarm is to use the factory remote first or start the car. Unfortunately, starting the car usually causes the horn to honk once first before it disarms and may set a service theft system light on the dash. Activating the locks only unlocks the car and does nothing to the alarm. The factory alarm will arm if you use the factory remote to lock the doors. On some Cobalts and Pursuits you can program the car to auto arm or if you relock the doors with a remote starter after they are already locked the alarm will arm. This is why the new module is needed. The company that makes Astrostart may also have a module out that interfaces with the factory alarm on these cars.
sparky
xtremej
Gold - Posts: 1,440
Posted: April 18, 2006 at 7:59 AM / IP Logged
I ran out of time yesterday, I talked to installler that was working with me and he told me no, we tried it, it didn't work . Sorry I was unable to post this last night05 Colbolt Disarm Wire -- posted image..
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
