How to connect 508D to 791xv
Covette03
Member - Posts: 36
Posted: April 17, 2006 at 7:59 PM / IP Logged
I just got in my 508D and now I want to connect it to the viper 791xv. I'm pretty sure I know how to connect it. thw red goes the 12v+ constant , the black goes to alarm ground, now how excatly do I hook up the rest. Do I connect it to the blue wire on the shock sensor. Can anyone help me with this install?
pss5075104
Copper - Posts: 144
Posted: April 17, 2006 at 8:49 PM / IP Logged
just solder the blue, and green wires together as well but make sure that you diode isolate each.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
Covette03
Member - Posts: 36
Posted: April 17, 2006 at 9:35 PM / IP Logged
so diode isolate each one of them to the blue wire of the shock sensor harness,4 pin connector then right? are those wires the major trigger and minor trigger  wires? Can I just connect the major only so I don't have to diode isolate? And which one is which?
Covette03
Member - Posts: 36
Posted: April 17, 2006 at 9:36 PM / IP Logged
Also is there a diagram anywhere for this install?
