95 Mustang, Black Widow 4150
longfellowdeeds
Posted: April 23, 2006 at 5:45 PM / IP Logged
hi, i am installing a black widow 4150 (alarm+ keyless entry) in my 95 mustang, this car has power locks but no keyless entry!, i need someone to walk me through installing it, i have the wires connected but all i hear is the relay's in the brain clicking! PLEASE HELP!!!
mo12v
Posted: April 23, 2006 at 7:17 PM / IP Logged
If you are sure your Mustang came WITHOUT Factory Keyless, then you will need to do a 5 wire Reversal.
Does your Unit have ON-Board relays??
Find your LOCK & UNLOCK wires ( PINK / Yellow & PINK / Green ) Kick Panel
Cut them in Half.
One side of cut wires will have 12 Volts when you Press the DRIVER Door Switch.  ( this will be called Switch Side )
One side of cut wires  will show Nothing ( this will be called Motor Side )
5 Wire Reversal:
? = your Unit wires if you have ON-Board relays
Lock:
? = Switch Side ( N / C )
 ? = Motor Side ( COM )
 ? = 12 Volts Constant ( N / O )
Unlock:
MO
longfellowdeeds
Posted: April 23, 2006 at 7:47 PM / IP Logged
ok, that helps me out with the locks, but why won't the unit act properly? all i get is click noise from the brain.
mo12v
Posted: April 23, 2006 at 8:38 PM / IP Logged
Not sure of your question??
Are you asking about the whole Alarm working "properly"? or the Door Locks??
MO
longfellowdeeds
Posted: April 23, 2006 at 10:46 PM / IP Logged
the whole alarm, i have all the wires except the door locks connected, and all the alarm does is makes a click noise and the alarm goes non-stop. why would the the brain make the clicking noise non-stop and the alarm go off non stop???  what do you have to do to get these alarms to work ???
mo12v
Posted: April 24, 2006 at 8:18 AM / IP Logged
If you are sure you have everything connected properly..........
Be sure the Alarm is NOT in Valet Mode.
Also, how long after Arming, does the Alarm Trigger??
MO
