Viper 791xv issues
uniball
Member - Posts: 21
Posted: May 23, 2006 at 11:28 PM / IP Logged
OK I have a Viper 791xv on my 03 Dodge Ram and have a few problems. My alarm is set and my only LCD remote is broken beyond repair. I have a new LCD remote ready to be programmed. I removed the brains so the alarm won't go off. How do I go in valet mode to shut off the alarm? How do I program the new remote? Thanks,
uniball
godblessdremil
Silver - Posts: 273
Posted: May 24, 2006 at 8:44 AM / IP Logged
Any shop should do that for free as its part of the warrenty. As for the Valet mode just turn your key to the on position and then just push the vallet switch. If i remember the number of times right here it is. Put the key to the on position, press the push button switch 9 times then push and hold, now hit the lock button on your remote, then let go of the push button.
Platinum - Posts: 12,488
Posted: May 24, 2006 at 9:04 AM / IP Logged
Turn ignition ON and then OFF & then press the VALET button within 10 seconds. The LED Will stay on solid if in VALET mode.
uniball
Member - Posts: 21
Posted: May 24, 2006 at 9:34 AM / IP Logged
Thanks guys I will give it a try.
uniball
duct tape
Copper - Posts: 125
Posted: May 24, 2006 at 10:12 AM / IP Logged
gotta make sure that a door is left open when  you do this, or it wont work.
