infiniti immobilizer bypass
murzik
Posted: May 28, 2006 at 4:57 PM / IP Logged
I have 06 G35 coupe with intelligent key. I try to install remote starter. Every thing looks ok, but I can’t get immobilizer bypass module 556U to work. If factory alarm is active car won’t start. If factory alarm is not armed or I live key in ignition car starts just fine. Do I need to do anything specific for infinity? Or do I need different immobilizer bypass module?
Chris Luongo
Platinum - Posts: 3,746
Posted: May 29, 2006 at 9:46 AM / IP Logged
Did you power up the RED / blue keysense wire as Ignition 2? You need to do tha if it has the Intelligent Key.
murzik
Posted: May 29, 2006 at 11:58 AM / IP Logged
Thanks, That was it.
However, I used ignition2 as starter 2.  What can I use for keysense?
