door lock that dont lock
catrisha
Posted: May 31, 2006 at 3:26 PM / IP Logged
Hello!
I have a 96 mitsubishi galant and install a keyless entry (from ebay). The problem is my right door! It works before I install the remote system, now it dont lock like the others. Im wondering if its electrical or mechanical? What should I do?
KarTuneMan
Platinum - Posts: 7,056
Posted: May 31, 2006 at 11:02 PM / IP Logged
Have you "unhooked" the keyless to see if it works without it? What did you "hook" too?
Lock is GRN/WHT NEG(-) drivers kick
Unlock is RED / GRN NEG(-) smae location.....
catrisha
Posted: June 01, 2006 at 2:49 PM / IP Logged
Thanks for the tip KarTune Man. I tried your suggestion today. I remove the keyless connection and put back the original central locking of the car. To make the problem worst, the right door lock work sometimes  and sometimes dont.
bmwpwner
Copper - Posts: 174
Posted: June 03, 2006 at 12:49 AM / IP Logged
take that switch and clean the contacts on the inside of the switch. also, after mitsu switches get older you can add relays to take the pressure off the switch rather than buy a new switch. good luck and hope this helps.
"I cannot teach anybody anything, I can only make them think."
-Socrates-
mad550
Copper - Posts: 201
Posted: June 03, 2006 at 7:57 AM / IP Logged
The next best option is to replace the factory locking motor with a generic motor and it should work fine with your factory module.
WOW Sight and Sound
Maroochydore
Nothing is impossible!
Do it right the first time or don't do it at all.
catrisha
Posted: June 03, 2006 at 3:52 PM / IP Logged
Thanks for the tips guys! Im sure this will solve my problem.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
