are starter wires usually neg polarity?
profuse007
Gold - Posts: 2,015
Posted: January 09, 2003 at 11:38 PM / IP Logged
are starter wires usually neg polarity? i have viper 600hf, i test this wire and it is neg
viper's instruction say this:
How to find the (+)12V starter wire with your multimeter:
2. Attach the (-) probe of the meter to chassis ground.
4. Turn the ignition key switch to the start position. Make sure the car is not
in gear! If your meter reads (+)12V, go to the next step. If it doesn’t, probe
another wire.
5. Cut the wire you suspect of being the starter wire.
6. Attempt to start the car. If the starter engages, reconnect it and go back to step 3. If the starter does not turn over, you have the right wire.
RufNUSD
Copper - Posts: 184
Posted: January 09, 2003 at 11:47 PM / IP Logged
so what makes you think you have a neg starter? last vehicle i saw with a neg starter was a rolls royce.......you must be balling son! if you are balling, what are you doing working unexperienced on your own car? Mel
Someone pass me that bottle.
profuse007
Gold - Posts: 2,015
Posted: January 10, 2003 at 12:17 AM / IP Logged
i check every wires and that is the only one that doesnt crank at all when i turn the key. i have  94 camry . but when i check on my older car which is a camry too, and it is the same. the car had an alarm on it. it was cutted off to plugged into the relay. am not too sure
jrilla
Gold - Posts: 1,498
Posted: January 10, 2003 at 6:58 AM / IP Logged
the 94 Camry starter wire is BLACK/ White in the main ignition harness. There is a white connector that the main ignition harness pugs into and the colors may change on the other side. Look on both sides for your color.
J Rilla
Owner/Installer
profuse007
Gold - Posts: 2,015
Posted: January 10, 2003 at 9:07 AM / IP Logged
that's the color wire i got, but it will only read 12v if i probe neg to that wire and pos to a 12 volt. but it is ok for this wire though?
jrilla
Gold - Posts: 1,498
Posted: January 10, 2003 at 9:31 AM / IP Logged
I am not sure what you mean
J Rilla
Owner/Installer
AlarmTech
Copper - Posts: 101
Posted: January 10, 2003 at 11:33 AM / IP Logged
are you sure your turning the key to START and not just RUN?
The Camry is no mystery. If you follow the directions exactly as you typed them, you'll see 12v on the BLACK/ white wire when the key is turned to START only.
Viper Equipped
