viper 791xv?
mikex1021
Member - Posts: 6
Posted: June 30, 2006 at 8:11 PM / IP Logged
siren keeps going off unless i open the trunk. the remote does not want to disarm the system, i just get a signal that the car is being tampered with.remote start does not work, no idea why, please help, its on a 94 integra gsr, if you know where each wire is hooked up to and what color please let me know?
mikex1021
Member - Posts: 6
Posted: June 30, 2006 at 8:13 PM / IP Logged
the car is a stick shift do i need to hook up the neutral safety switch, do i need to use any relays?
captainzab
Silver - Posts: 606
Posted: June 30, 2006 at 8:59 PM / IP Logged
Why would siren go off and stop when you open the trunk? Is it a bad remote? Are you asking to install this and need the vehichle diagram? If so, do a search on your vehichle. Also, plese be clear on what you are asking!!!
And if you are remote starting a manual transmision car, you must use a relay to bypass clutch using status wire.
Look at relay for extra info
swamprat323
Gold - Posts: 1,335
Posted: July 01, 2006 at 8:30 PM / IP Logged
is the siren got off a full vol or is it low, if low check the ground of the alarm and siren.
check the atenna unplug it an dplug it back in to see if it is the remotes, ahve you tired both of them, do any other bottons on the remote work.
